#1 |
Furnace inlet vent problems
I recently noticed that the vent that was installed for my furnace is sucking in a lot of debris from outside into my furnace room. It was installed only 4 inches above the ground level. It also snows here in Utah so I expect it will be covered completely in the winter. I looked at the code and it looks like it was not installed according to code. From what I understand this is what the code says:
1. Must be installed 12 inches above grade or above expected snow level. 2. Must be at least 4 ft from a window that opens or a door or 1 foot above. Does this sound right? I would like to understand so I can get this located in a place that is up to code. |
#2 |
12'' above anticipated snow level and 4 ft for single pipe and usually 12 " for two pipe systems[intake and exhaust next to each other].Installation manual should show how to install termination if it needs to be raised higher.
#3 |
this may help
#4 |
Furnace inlet vent problems |
#5 |
I personally never seen one installed like that here in pa..but maybe in your area they do that....what does your neighbor have in the way of intake set up....?????ben sr
#6 |
the furnace has the exhaust pipe going out the side of the house. The input tube is just open to the air in the basement. But then above the furnace is the 6 inch tube that leads outside.
I have two units in my home. One for the upstairs in my attic(immediately under the roof) and one for the main floor(in the basement). The basement doesn't have vents and is unfinished. The input and exhaust pipes for the upstairs unit goes out the roof. Both tubes. I didn't get a chance to look at the neighbors before it got dark outside. |
#7 | |
Furnace inlet vent problemsQuote:
| Display Modes | |
| Problems with inside the wall dryer vent | darsunt | Appliances | 2 | 11-08-2011 07:58 AM |
| gas water heater vent into furnace vent??? | Master Brian | HVAC | 2 | 05-08-2011 01:16 PM |
| Rheem Criterion Gas Furnace Problems | boons25 | HVAC | 2 | 01-24-2009 11:48 AM |
| Moving furnace vent | Pitch11 | HVAC | 15 | 10-24-2008 05:06 PM |
| furnace and or electrical problems | tuasoi | General Discussion | 4 | 11-29-2007 01:50 PM |
