-   -   Furnace inducer motor always running, even temp reached (http://www.diychatroom.com/f17/furnace-inducer-motor-always-running-even-temp-reached-83398/)
Ballastar 10-08-2010 03:42 PM
Everything looks working properly, just inducer does not stop, even fire and blower stopped, what's wrong!?
kenmac 10-08-2010 04:23 PM
If vent motor runs all the time even with system on a/c. Could be stuck relay on control board. I have seen this happen. Had to replace control board
HVAC_NW 10-08-2010 04:54 PM
Unfortunately, that's a problem with modern equipment. They're using less and less discrete components. Gear chipped in window regulator for car? You've got to buy the entire window regulator including motor for $300.
If you know exactly which relay it is, you could rebuild the board though. The foot print doesn't have to match as long as the coil voltage and contact configuration and ratings meets or exceeds the existing relay.
