Furnace Indicates Calling For Heat But No Fire - HVAC - DIY Chatroom Home Improvement Forum
Old 10-29-2010, 08:03 PM   #1
furnace indicates calling for heat but no fire
I have an XV90 Trane furnace which the indicator light blinks continuous ( which according to manual means calling for heat) but doesn't fire unless I turn power off and back on? Any thoughts? I swap out thhermostate bu;t same issue
pocketrods is offline   Reply With Quote
Old 10-29-2010, 08:09 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Your furnace has more than likely gone into a soft or a hard lock out and when you turn off the power and turn it back on you reset the control board.
Next time it does this count the blinks or flashes. As the led flashes it is telling you a fault code. To count the flashes, watch the led and when there is a 2 or 3 second pause between flashes start counting.
Something like this
Flash, Flash, Flash,,,,Flash, Flash, Flash,,,,Flash, Flash, Flash
Fault code 3. Somewhere on the furncce door there should be a fault code list that will tell what the code means....go from there
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
plywood on fire rated wall acerunner Building & Construction 9 11-18-2016 06:15 PM
Furnace won't fire, exhaust fan hot and won't start tex800 HVAC 14 10-08-2010 06:48 PM
Comfortmaker furnace won't fire Scott Little HVAC 26 09-23-2010 07:38 PM
new (used) garage furnace coldnorth HVAC 11 12-31-2008 08:19 PM
Add-on Wood furnace billmac HVAC 3 06-18-2008 09:17 PM
