Furnace Ignitor Clicking - HVAC - DIY Chatroom Home Improvement Forum
Old 12-12-2009, 12:01 PM   #1
Furnace ignitor clicking
Hi there, first post from me. I've got a problem with my Carrier 58GS-075 furnace that I'm trying to nail down. When the thermostat calls for heat from my furnace the pilot lights but the spark ignitor continues to click even after the pilot is lit. I have cleaned the spark electrode (the metal rod with orange tube coming from it) and it didn't seem to help any.
Also and more concerning to me is that occasionally when the burners ignite, they go out immediately, only to relight again. They ignite and go out several times before they stay lit and furnace operates normally then.
Thanks if you can help me out any. I did post a video of the ignition sequence on youtube to help troubleshoot this. Video Link
Joe028 is offline   Reply With Quote
Old 12-12-2009, 12:51 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,756
The device that the 3 wires attach to is a bimetal switch/flame sensor device. It hardens up with age and is not proving the pilot ON and needs to be replaced. They are not cheap $$.
Old 12-12-2009, 12:57 PM   #3
HvacWiz's Avatar
Rewards Points: 252
What yuri said, you need to replace the pilot assembly.
HvacWiz is offline   Reply With Quote
Old 12-12-2009, 01:01 PM   #4
Thanks for the response. In your opinion if I replaced that part could I keep the spark electrode with the white casing and orange tube, or does that need replaced as well at the same time?
And just to clarify, I attached a picture of the part that you think needs replaced...is this correct? 3 wire pilot burner. I found it online about $65, that sound about right?
Thanks again.
Old 12-12-2009, 01:05 PM   #5
Hvac Pro
yuri's Avatar
Thats the one and it is a good price and you only need it.
Old 12-12-2009, 01:07 PM   #6
Thanks guys. Think I just stepped on a gold mine of a site here. Appreciate the help!
Old 01-18-2010, 04:19 PM   #7
follow up
I've had the new pilot assembly in my furnace for a while now and it works great for the most part. It still clicks a lot though and it happens when the pilot flame is not in direct contact with the sensor. The flame jumps around a good bit and when it isn't contacting the sensor a spark clicks. Can I adjust the pilot flame so it is more steady and doesn't jump so much? Thanks for any help.
Joe
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 02:24 AM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 07:06 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
