Furnace Ignitor - HVAC - DIY Chatroom Home Improvement Forum
Old 05-15-2014, 06:52 PM   #1
Furnace ignitor
I have a Ruud Silhouette furnace model #UGDJ-10EAMER. Last year it would light but shut down shortly after. I cleaned the gas sensor with a dollar bill and it worked all winter. I didnt use the furnace for a few weeks due to warmer weather. Now the furnace will start to cycle and then shut down. I noticed that the ignitor does not glow. It is the type of ignitor that connects with 2 wire nuts. I wanted the part # of the ignitor so that I could order the correct one. Any other ideas I could try instead of replacing the ignitor?
mshep1 is offline   Reply With Quote
Old 05-16-2014, 05:35 AM   #2
An old Tradesmen
Rewards Points: 6,132
Use a meter and see if the ignitor is getting voltage.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (05-17-2014)
Old 05-16-2014, 06:29 PM   #3
how
Rewards Points: 1,070
Do you have a flashing diagnostic light /code on your furnace that you can match against the legend inside. It might indicate a plugged inducer line to the pressure switch,or,or,or.
how is offline   Reply With Quote
Old 05-17-2014, 01:13 AM   #4
I'm Your Huckleberry
Rewards Points: 2,270
heating sequence of operations:
Inducer (exhaust) motor starts, proving exhaust capability and thus moving on to second sequence.
Pressure switch closes.
Ignitor lights ups
Gas valve opens
Furnace lights up with flames
20-30 seconds after fire, blower comes on.
Hope that helps
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Heil Furnace problem - is is the undersized vent? mpmusicny HVAC 8 11-20-2012 01:47 PM
Furnace ignitor clicking Joe028 HVAC 6 01-18-2010 05:19 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Snyder General Gas Furnace - No Gas to the ignitor Hanela HVAC 5 12-04-2006 12:37 PM
