Furnace Ignition Troubleshooting - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-14-2009, 12:27 AM   #16
Can't test the sensor amps..
My multimeter is not heavy duty and goes only up to 0.25A..
buju is offline   Reply With Quote
Old 01-14-2009, 02:30 AM   #17
Update...
It's too late to repeat, so I hope it's ok to paste a link to my last posting in another bb: http://forum.doityourself.com/gas-oi...con-the90.html
I will update tomorrow. I mean today... it's 3:30 AM EST.
Darn it..
Good night and thanks.
Old 01-14-2009, 06:03 AM   #18
With ohms that high I would recommend a new ignitor.
SKIP4661 is offline   Reply With Quote
Old 01-14-2009, 12:12 PM   #19
I was thinking of changing both the HSI and the controller
They seem to be both flaky - high resistance on the HSi side, an obvious relay flakiness on the controller side. They actually may even be related..
My main issue with changing the HSI/ flame sensor is that it is buried deep into the guts of the furnace and I'd have to take out the GV assembly - not something that I'd want to do. What a stupid design. I can'even clean the darn thing.
Old 01-14-2009, 04:13 PM   #20
You got a single burner set up with a deep green body? That's older than ten years man.
You need an up date kit for which you are ten years over due!
hvaclover is offline   Reply With Quote
Old 01-14-2009, 08:54 PM   #21
Not sure if it's that old..
Can't see the burner, but I think that it is indeed a single burner design.
For now I will leave alone the "can opener", not cut any additional opening, and try to find a way to reach the HSI.
If I can't find a way I will try to take a picture and upload it somewhere.
I'll be back. Thanks.
Old 01-14-2009, 10:33 PM   #22
Dude it comes apart in five minutes
Old 01-14-2009, 10:41 PM   #23
The HSI is screwed inside the curber assembly, which is connected to the GV
*EDIT* Can't seem to be able to edit the title.... I meant to write "inside the BURNER assembly", of course..
The burner is a single model, ending with a round plate.
Gees, that's one assembly and there's no way to take it out without taking out the gas line...
3 questions:
1) I will likely order the controller now... If that does not work I will do the HSI thing. I would like to stay away from dismantling gas piping.
Question, what do you think about this replacement controller: 50E47-843 White Rodgers UNIVERSAL IGNITION MODULE **Replaces many others... see replacement cross-reference here** - HVAC Products Any experience with it? Would it work ok, as they say that it is?
Is it pin-to-pin compatible with the Robert Shaw I am replacing: HS780-34NL-306A?
Just in case that you know.
2) If/ when I want to reach the HSI to replace or whatever - can you tell me how the piping is normally screwed?
I have the pipe connected like this: elbow-pipe-connector-pipe-GV (that surely cannot turn)
How would I disconnect? My quess is that one of the pipe screws or the connector screw in in the opposite direction.
Sorry I am a total rookie at screw-in piping...
I want to make sure that I am turning the right piece and not crack/ force anything.
3) I know how to check for gas leaks. What do you recommend to use for connection sealing? I suppose that the tape used for water pipes is not the best for this purpose.
Thanks a lot.
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
help on a gas furnace ignition problem zorroo HVAC 14 11-21-2008 03:20 PM
intermittent ignition problem with American Std 90 propane furnace jabass HVAC 5 11-21-2008 06:16 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
