Furnace Igniter Does Not Glow At All - HVAC - DIY Chatroom Home Improvement Forum
Old 12-15-2011, 09:30 PM   #1
Furnace igniter does not glow at all
Luxaire furnace: Problem - Igniter does not light, fan runs when on, igniter does not appear to be cracked. What do I check for?
Earl Francis is offline   Reply With Quote
Old 12-15-2011, 09:48 PM   #2
Rewards Points: 344
need more info...does the inducer motor start when t-stat calls for heat....pictures would help..
Old 12-15-2011, 10:31 PM   #3
biggles's Avatar
ring the wires out disconnect the 2 from the ignitior glow coil should have continuity as if the 2 leads are together set a digital in OHMS
When to replace a furnace? stanlam HVAC 3 07-20-2010 08:21 PM
Have an oversized furnace turfgrass HVAC 5 02-22-2010 04:48 PM
Help! with Concord 80+ gas furnace + T-STAT joryeln HVAC 0 09-16-2009 01:23 PM
Oil furnace / tank questions... pure_energy1 HVAC 26 06-22-2009 09:47 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 02:12 PM
