Furnace Humidifier - Polyethylene Tubing Okay? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-13-2012, 06:45 PM   #1
Furnace Humidifier - Polyethylene tubing okay?
Hi,
I am installing an Aprilaire 600 Humidifier and I bought some 1/4 inch polyethylene tubing to connect the humidifier to the saddle valve. However, now I am wondering, is it okay to use regular (non PEX) polyethylene tubing for connecting to the hot water line, or should I get PEX tubing instead?
Also, can I install the saddle valve vertically, or does it need to be installed horizontally?
konradsa is offline   Reply With Quote
Old 10-13-2012, 07:38 PM   #2
Rewards Points: 610
DHW Temp usually not too hot for plastic hose but if it goes out of control would likely cause it too stretch or melt resulting in excess water damage..
I personally would go with PEX or copper
techpappy is offline   Reply With Quote
The Following User Says Thank You to techpappy For This Useful Post:
konradsa (10-14-2012)
Old 10-14-2012, 04:34 PM   #3
Thanks, went and got some soft copper tubing.
Old 10-14-2012, 08:11 PM   #4
Rewards Points: 582
Originally Posted by konradsa View Post
Hi,
while i don't like saddle valves you can install them any direction ......ben sr
Old 10-15-2012, 08:41 AM   #5
Rewards Points: 610
just don't over tighten..and tighten evenly
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Armstrong furnace how to wire humidifier doublewide6 HVAC 35 12-25-2010 11:25 AM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Installing a Furnace Humidifier pieman312 HVAC 1 01-08-2008 09:58 PM
