Furnace Help...won't Heat Past 67 - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-06-2011, 08:13 PM   #16
Originally Posted by ben's plumbing View Post
please check rotation again and biggles make good point.. fan and limit should be above furnace not that close to burnners
This is me eating crow. I reversed the motor and bingo. Thanks for the help everybody.
goodtimes is offline   Reply With Quote
Old 12-06-2011, 08:18 PM   #17
Rewards Points: 582
thats great as i said we all make mistakes even the best..just keeps us humble..you did a very good job....ben
Old 12-07-2011, 03:53 AM   #18
An old Tradesmen
Rewards Points: 8,168
Many years ago. I was rushing on a motor change out. Fired up the new motor and felt air blowing out of the register on the supply plenum. called it good and left. 2 hours later, the customer calls and says the burner keeps cycling on and off. Went back, and found it running the wrong direction. Ooops. It happens.
Just glad it was something simple.
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 03:59 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Service tech won't repair furnace with cracked heat exchanger. GloBigRed HVAC 16 11-18-2010 02:27 AM
first time startup on Bryant furnace - furnace calls for heat and will not stop luvheat HVAC 22 02-14-2009 08:56 AM
