Furnace Help - Tappan SGUF 80 D 24 E7 - HVAC - DIY Chatroom Home Improvement Forum
Old 11-30-2008, 01:12 PM   #1
Silly question. I am trying to light the pilot light on my furnace and just can't seem to find where to put the match. Does anybody know where the pilot light is on this model Tappan furnace?
Lemon Funk is offline   Reply With Quote
Old 11-30-2008, 01:21 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,414
If the gas valve has a thin copper wire(thermocouple) from it to the burner area and a knob with on/off/pilot positions then it has a pilot light. If not it probably is a newer furnace with a HSI (hot surface igniter) and no pilot light. Follow that wire to the pilot burner, Turn knob to pilot/hold down/light pilot with match/hold for 60 seconds and slowly release. If it goes out call a tech to replace thermocouple/clean pilot burner etc.
Old 11-30-2008, 01:52 PM   #3
Thanks Yuri. I got her going. I just needed to keep the lighter on the pilot a bit longer and it finally fired up.
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 08:01 PM
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Add-on Wood furnace billmac HVAC 3 06-18-2008 10:17 PM
