Furnace Help. Brrrr - HVAC - DIY Chatroom Home Improvement Forum
Old 10-11-2010, 05:47 PM   #1
Furnace Help. Brrrr
Hello everyone. I'm having furnace troubles. It is a Payne 398aaz036080aaka gas furnace. We turned it on because it is now cold and this is what it does.
As soon as we turn on the thermostat, a fan/blower starts up (not the main one). Then i can see the pilot flame going. The little flame stays on for ~30 seconds, and then goes off again, and the little blower shuts off ~15-30 seconds later. After about 2 minutes, the same thing happens again. The main burner never comes on. What can i check or what can i do? Thanks in advance.
Last season, it worked, although it would cycle non stop. As in the heat would come on, for about a minute, then stop. Then come back on after a few minutes, then off again. It kept doing that.
I'd like to know what the issue can be, and if there's a cheap fix. I don't want to buy a new furnace, because we cannot afford one unless we put it on credit card, which i DO NOT want to happen.
florin1 is offline   Reply With Quote
Old 10-11-2010, 08:55 PM   #2
HVAC / Plumbing
Sounds like it's not proving pilot flame. If pilot has a sensor try to clean it.. It you have a circuit board . look for blinking light. Probably will be located in the blower compartment
kenmac is offline   Reply With Quote
Old 10-11-2010, 09:42 PM   #3
I can see the little pilot flame trough the window. Its working.
Old 10-12-2010, 04:30 AM   #4
An old Tradesmen
Rewards Points: 7,806
You may see it. But that doesn't mean the control knows it burning.
The control board should have a light that flashes an error code. look to see what code its flashing.
Could be a dirty flame sensor. Or something else. So look for the error code.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
BRRRR! NO HEAT! PLEASE HELP! Old Carrier Furnace! joeraccio HVAC 6 10-11-2010 09:07 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
