Furnace Help - HVAC - DIY Chatroom Home Improvement Forum
Old 11-25-2007, 04:05 PM   #1
Furnace Help
I had a problem last year with power going out in certain rooms in the house when the furnace was on, i had an electrician look at the circuit breaker and tighten some of the screws which he said were loose after that i havent had any problems with the power going out. Looks like it started up again and it only seems to happen when the blower kicks in on the furnace. Could a furnace blower cut power to certain portions of the house. I went ahead and tested this today but cutting power to the affected areas of the house via the circuit breaker by leaving just the lights to the furnace room and furnace on, and again when the blower kicked in the lights flickered a bit and then the power went out on the furnace. Can anyone help not sure if this is a furnace issue or Electrical issue.
Ian
tuasoi is offline   Reply With Quote
Old 11-25-2007, 05:28 PM   #2
scotch on the rocks
hvactech's Avatar
by code your furnace should have a 15 amps. dedicated circuit.
hvactech is offline   Reply With Quote
Old 11-29-2007, 12:54 PM   #3
Ian
Problem Fixed
All it was was a loose bolt to one the legs that was going into the house from the meter block. Thanks to everyone who answered.
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 01:24 AM
Furnace Exhaust To Outdoors celticFC HVAC 1 09-01-2007 01:27 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 05:00 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 09:23 PM
