Furnace Heats Only With Thermostat On Cool - HVAC - DIY Chatroom Home Improvement Forum
Old 11-12-2011, 10:17 PM   #1
Furnace heats only with thermostat on Cool
Honeywell RTH2300 wired by instructions, NG furnace, elec AC, furnace ignites and heats with System Switch on "cool", does not ignite on "heat". Labeled or switch built backwards?
Mikaele is offline   Reply With Quote
Old 11-12-2011, 10:53 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
you've miswired it. take pics and post them of all wiring.
Doc Holliday is offline   Reply With Quote
Old 11-12-2011, 11:37 PM   #3
biggles's Avatar
remove the stat from the subbase and tell us the olor of the wires going to the lettered screw terminals.....shut the furnace power before flipping wires up on the stat.....check this first should be R/RED (24V hot) Y/YELLOW(cool) W/WHITE(heat) G/GREEN(fan).....if you jump R to G-(fan) R to Y-(bump condenser ON) R to W (heat)
Old 11-13-2011, 09:41 AM   #4
You've probably got the white heat wire on common, as common is used for cooling to bring on the condenser.
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Lux Thermostat heats on low but not on high? eepto0237 HVAC 1 02-16-2011 11:20 AM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Can't turn furnace fan on from thermostat control cnnd2010 HVAC 0 06-18-2010 11:37 AM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 04:57 PM
