Furnace Heater Control Board - HVAC - DIY Chatroom Home Improvement Forum
Old 01-12-2010, 06:41 AM   #1
Furnace heater control board
Help!!! I have a conventional gas heater made by Bryant. I turn my termostat to heat and I hear a click but nothing is on from the furnace. If I turn on cool or auto then it come on. At first I thougt it was a tranformer but I check it and it's fine. So I think it's the board cause the led light isn't blinking normal. Is there any way to check the board? Yes there's power coming in to the board, that's all I know. Thank you in advance for all your help!
Airec is offline   Reply With Quote
Old 01-12-2010, 07:52 AM   #2
An old Tradesmen
Rewards Points: 8,144
It was probably blinking an error code to you.
You have to read the number of blinks. Then look at the error code, to see what its telling you to check.
Old 01-12-2010, 07:39 PM   #3
where can I find out if it blink 8 times? where's the error code locate at? Thanks
Old 01-12-2010, 07:52 PM   #4
An old Tradesmen
Usually on the inside of the blower panel door.
Old 01-12-2010, 08:04 PM   #5
ok thank you
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
furnace circuit board hk42fz007 ccmyers2 HVAC 2 12-02-2009 09:10 PM
Bad Control Board? Bullage HVAC 16 11-17-2009 10:12 PM
HELP!! NEW Control Board & Same Problem!! Steve72 HVAC 3 02-11-2009 02:48 PM
New to the board & need furnace advice... ehinchman HVAC 18 03-05-2008 07:28 PM
