Furnace Has Burn Smell And Blower Motor Doesn't Start - HVAC - DIY Chatroom Home Improvement Forum
Old 01-16-2012, 03:15 PM   #1
Furnace has burn smell and blower motor doesn't start
I have a Lennox 80UHG 3/4 - 100A-2
Problem: Thermostat calls for heat and the whole cycle starts up with the inducer runs, igniter lights up and flames burn for about a minute or so...usually the blower motor fires up and blows the heat thru the house, but the blower never comes on (I have had the blower motor tested and the capacitor too...both work and the fans spins freely with no issues) then shortly after it shuts off and give an error code LED1 (Slow Flash) LED2 (ON) and the description is Primary or Secondary Switch open. When the blower fan usually comes up I hear a click but nothing happens. The Metal plate that has the circut board mounted to it also has a separate bulky thing with several wires coming out that seems to hum pretty loud and I never remember hearing it before before and after the whole start up cycle...also once it shuts off the whole house smells like burnt wood...that seems to trickle out of the vents
Any Ideas?
marcusal6 is offline   Reply With Quote
Old 01-16-2012, 03:16 PM   #2
Any Ideas?
You have a bad HFR (heater fan relay) on the main board, you will need to have a qualified lennox tech out to replace the board.
harleyrider is offline   Reply With Quote
The Following User Says Thank You to harleyrider For This Useful Post:
marcusal6 (01-16-2012)
Old 01-16-2012, 03:22 PM   #3
I'm Your Huckleberry
Rewards Points: 2,270
What happens in cooling mode or fan on? It could be a bad relay or a bad fan motor/cap.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 01-16-2012, 03:24 PM   #4
quote taken from OP:
Old 01-16-2012, 03:27 PM   #5
hAiR today, bAld tomorrow.
Thanks.
Old 01-16-2012, 03:31 PM   #6
A burn smell is usually the motor. Good luck.
Thanks.
Old 01-16-2012, 03:39 PM   #7
I guess you have never seen a circut board that blew a relay off of it? i have seen it a thousand times, can smell it when i pull in the driveway............yeah, im that good
Old 01-16-2012, 03:52 PM   #8
[QUOTE=Doc Holliday;824674]What happens in cooling mode or fan on? It could be a bad relay or a bad fan motor/cap.[/QUOTE
the blower motor doesn't run in cool or fan mode...so nothing happens
Old 01-16-2012, 03:57 PM   #9
post a picture of your circuit board..........it will show a fried relay, you will see black soot and smell the cooked relay. we can have 20 or 30 more post about what could be wrong in 50 different pretend scenario's if you would like.........
Old 01-16-2012, 05:00 PM   #10
Thanks Harley Rider!!!...I took the board off and you are exactly right...black spot on the back of the board...getting costs for a new one...so far $223 is the only cost I got...the rest of the shops are closed around here...does $223 seem like a fair price?
the board had a label on it for part info...
9840
50A65-120
Lennox
12L6901
Old 01-16-2012, 05:01 PM   #11
yes......thats a good price !
Old 01-17-2012, 02:47 PM   #12
New board dropped in and heat is up and running. There is still a slight burning smell coming from the heater at startup...maybe it's just some felt over smell???...not as strong as before. Could there have been another problem in the furnace to cause the short in the relay...I just don't want to burn out the new board... do you have any idea what causes the blown relay? I just want to avoid this if at all possible.
you gave great advice and knew exactly what was wrong
Thanks Again!
Old 01-17-2012, 02:54 PM   #13
HVAC Tech/ Browns Fan
Heck I'm better. I can smell it over the phone when I'm talking to the customer.
Tator1076 is offline   Reply With Quote
Old 01-17-2012, 03:09 PM   #14
how
Rewards Points: 1,104
That smell should be a 1/8 th of what it was but it will hang around for a few more days.
how is online now   Reply With Quote
The Following User Says Thank You to how For This Useful Post:
harleyrider (01-17-2012)
Smell coming from all floor registers. John_W HVAC 10 08-07-2015 06:42 PM
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 12:57 PM
Blower on Furnace Keeps Going Out gatesj1221 HVAC 6 02-09-2011 02:35 PM
Ruud Furnace blower /igniter jammerdc79 HVAC 1 11-17-2009 06:13 PM
Gas Furnace - Burning smell at return blakemcginnis HVAC 4 01-26-2008 08:29 AM
