Old 01-07-2009, 09:23 PM   #1
Furnace goes straight to lock out mode
I have a Heil furnace and when it tries to come on within a second or 2 of trying to come on it goes straight to lock out mode. The computer board,limit and roll out switch has been replaced what else could it be.
mardar1994 is offline   Reply With Quote
Old 01-07-2009, 11:03 PM   #2
What is the model and serial numbers?
SKIP4661 is offline   Reply With Quote
Old 01-09-2009, 08:58 PM   #3
My Heil furnace goes straight to lock out mode and the computer board, limit and roll out switch have been replaced. The serial number on my Heil furnace is L0238 86773 and the model number is N9MP2050B12A3
Old 01-09-2009, 09:13 PM   #4
JohnH1's Avatar
1st Does the board give any flash code?
2nd What does happen durring operation before it locks out.
3rd This compleatly locks out the 1st time and has to be re set or will it retry a couple of times before a full lock out?
JohnH1 is offline   Reply With Quote
Old 01-09-2009, 09:28 PM   #5
Does this furnace use the smart valve? This can be verified by the numbers on the gas valve, they will start with SV. If so you may have a bad ignitor.
Old 01-09-2009, 10:02 PM   #6
The new and old board both actually doesn't have a light on it. The furnace door has a chart that tells what the flashes means but there is no actual light on the old board (2) When it tries to come on you here the main motor try to kick in but the whole thing locks out within a second or two of trying. (3) And it goes to full lock out the first time it tries to come on
Old 01-09-2009, 10:05 PM   #7
Old 01-09-2009, 10:16 PM   #8
JohnH1's Avatar
Sounds like maby the wrong board was installed or if it is a universal board it may have been wired wrong.
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Bryant Furnace Lock Out DADDY31 HVAC 9 01-25-2009 01:04 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 02:12 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
