Old 02-04-2011, 09:38 AM   #1
Furnace goes out frequently
My Snyder General Comfortmaker (8/91) model GUG07A012IN Will go out with the flashing LED light inside. I can turn off the power switch and turn it back on to reset it. It will run for a while, then kick out again. What can I do to fix this? It seems this has electronic ignition and will fail to light 3 times before it has an external lockout. My manual states if it was the ignition modual, the LED would not flash, but be a steady light.
lebnurse is offline   Reply With Quote
Old 02-07-2011, 02:57 PM   #2
The flashing LED is giving you a code. Your supposed to count the number of flashes, there should be some kind of sticker on the furnace telling you what the fault code is, it may be on the inside of the blower door. I'm not sure on a Snyder General. But from what you describe it is an ignition fault, you say it tries to light three times before it locks out? So what happens? Do you see the ignitor glow? Do the burners actually light for a couple of seconds then shut right off? If they do, it is probably just a dirty flame sensor.
GhostRider96 is offline   Reply With Quote
Old 02-07-2011, 05:07 PM   #3
Ghostrider gives good advice.
Check this out:
http://www.youtube.com/watch?v=I86jo...eature=related
diyorpay is offline   Reply With Quote
Old 02-08-2011, 09:38 AM   #4
Thumbs up
Actually, I replaced the flame sensor and have not had a problem in the last 4 days. Thanks for the posts.
Old 02-08-2011, 10:05 AM   #5
Experienced
Jackofall1's Avatar
Another problem solved by a DIY'r, congrats on your success.
Mark
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
