Furnace Gas Valve Problem? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-01-2010, 10:24 AM   #1
About every 2 days my Bryant furnace fails to respond to the thermostats call for heat. If I disconnect the wires to the gas valve (coming from the control board), then reconnect them, the furnace lights up and works perfectlly for a day or two. At that point I have to repeat the procedure to get the unit to work again. Shutting the 110v feed off, then on, has no effect. The control board is new. I'd be grateful if someone would tell me what is going on and how to fix it.
heavenboundbike is offline   Reply With Quote
Old 02-02-2010, 06:46 AM   #2
HVAC Tech/ Browns Fan
What kind of pilot it has? Is it standing , spark, or glow. If its spark bimetal pilot. You will need to clean that metal part were the flame from the pilot its. Also clean pilot too.
Tator1076 is offline   Reply With Quote
Old 02-02-2010, 08:15 AM   #3
It's a hot surface ignition system.
Old 02-02-2010, 09:07 AM   #4
Check flame sensor
Old 02-02-2010, 10:00 AM   #5
The flame sensor and control board are brand new. The ground connections are solid. I'm thinking, at this point, that I should replace the ignitor and if that doesn't fix the problem, it's likely the gas valve. Is my thinking logical?
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Help troubleshooting furnace problem robert_ HVAC 21 02-15-2012 08:04 AM
Leaky furnace valve billinak HVAC 9 11-01-2009 07:11 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
