Furnace Gas Valve - HVAC - DIY Chatroom Home Improvement Forum
Old 10-01-2011, 12:53 PM   #1
furnace gas valve
Having problem with my furnace pilot light. The pilot is very weak and not enough to light the furnace. I can trick it by keeping the thermocouple hot until the furnace lights, I seem to have adequate gas pressure for the burners but a very weak pilot. Does a gas valve go bad controling the pilot light? Any thoughts? Heil furnace- sv9541 gas valve- auto pilot
okweldit is offline   Reply With Quote
Old 10-01-2011, 08:10 PM   #2
Sounds more like the gas valve than the thermocouple to me possibly since you do have a flame but a weak one. The thermocouple is what sends signal to the gas valve to allow gas to flow. Either that or possibly the orifice is dirty or clogged.
jpingra5 is offline   Reply With Quote
Old 10-01-2011, 09:30 PM   #3
HVAC Tech/ Browns Fan
You need take pilot apart and clean out the orifice. That a very small hole a piece of a wire brush can go through that hole to make more flow of gas
Tator1076 is offline   Reply With Quote
Rheem 80% Furnace Short Cycling rlukas79 HVAC 0 12-19-2010 04:27 AM
How to Adjust mixing valve on furnace? maxpower_454 Plumbing 2 10-08-2010 08:59 AM
Furnace Gas Valve Problem? heavenboundbike HVAC 4 02-02-2010 11:00 AM
Leaky furnace valve billinak HVAC 9 11-01-2009 08:11 PM
Leaking Presure valve on furnace Carloscda Plumbing 7 02-12-2009 02:27 PM
