Old 10-15-2010, 01:38 PM   #1
furnace gas supply shuts off quickly
Last week I had a 14 year old Trane furnace cleaned and checked out. First use since was this morning and it turns out that the gas shuts off a few seconds after ignition. I bypassed the thermal limit switch and get the same results.. The diagnostic light is a constatn flash. Any suggetions?
amyjamie is offline   Reply With Quote
Old 10-15-2010, 02:10 PM   #2
HVAC / Plumbing
Use some steel wool & clean flame sensor
kenmac is offline   Reply With Quote
Old 10-15-2010, 05:00 PM   #3
Thanks for quick response. Removed and cleaned, but still the same result. Is it possible that sensor bad? Have continuity from sensor to control
Old 10-15-2010, 07:59 PM   #4
hvaclover's Avatar
never. ever. jump. out. a. safety. limit.-
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 10-15-2010, 10:37 PM   #5
newtech's Avatar
Have the company come back and re-check it... It's only been a week since they were there...
newtech is offline   Reply With Quote
Old 10-15-2010, 11:11 PM   #6
HVAC / Plumbing
Could be bad sensor, bad connection at board, bad connection at sensor,bad ground, bad board
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Natural gas forced furnace - Burner shuts off prematurely scooter100 HVAC 9 01-25-2009 11:46 AM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 08:06 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
