My name is Carol. We just took over a construction project from bank. It is about 60-70% done. We are trying to pass the rough framing inspection next week.
This a 2 story duplex in San Jose, California. I noticed the furnace in 2nd story utility closet seats very close to the edge (about 2 1/2 inch.) I did some research on internet and find out the clearance at front of the furnace is suppose to be 6". I also looked up the manufacture specifications and it requires only 3" for the front clearance. But, after adding the thickness of the door, we only have 1 1/2 inch for the clearance.
The back of the furnace is already against the wall and have no space to move further. The unit is completed connected with pipes that goes to each room. It is very difficult to extend the back side of the utility closet to move the furnace.
Anything we can do other than push the wall out and move the furnace? May be have a different type of door for the utility closet?
There should be a label inside the furnace that states the clearances.
Take the doors off of the furnace and look on the sides for the label.
Where does the furnace get it's combustion air supply from?
I agree.
However, the furnace will still be serviceable with the door installed.
I think what the OP is looking for is clearance from combustibles.
The furnace is located on the second floor.
Even with a vented door, where would this combustion air come from?
Around here, we install a combustion air intake from the outdoors to the furnace area.
Depends how airtight the house is. A combustion air pipe is a very good idea as long as it does not get kinked/blocked etc etc. I would use a metal louvered door also.
Rob, did you know all our furnaces will have to be 90% efficient Jan1/2010. Oh Joy! http://www.hrai.ca/
Check the whats new column. "Changes to furnace standards". Venting is going to be a huge pain in the azz with some homes.
Not trying to Hi-jack but I sure feel sorry for the headaches ahead for you guys in Canada. I can only think of the headaches here in the US if this standard was put into effect here.
On a side note I wish it was here. With all this stimulas money flying around here it should have went to the tax payers to do something like this than pad all the overpaid CEO's
Sorry for not been clear - the clearance is from the combustible.
I found 3" front clearance from combustible on the installation guide.
There is a opening to the attic to get the combustible air.
We have some overpaid politicians and Senators that are not worth their keep here. Going to make life interesting in some of the rowhouses that are close together/Archie Bunker type neighborhoods where they are 4 feet apart. It is always the poor people who get shafted.
If the door is solid/no louvers and very close to the front of the furnace it may interfere with the furnace's ability to suck air in for the burner and become a safety hazard as well as trip the pressure switch. A louvered metal door will allow sound into the house. A sealed combustion high efficiency furnace would be a better choice. It needs to be vented thru the roof or outdoors thru a wall. Life is not easy.
York/Luxaire is trying to one up everyone in the advertising dept. Under laboratory conditions one model may hit 98%. Anything over 92% efficient is fine. There is still a lot of water vapor and some sulphur and other byproducts of combustion to get rid of. We got a couple inches of snow to get rid of, want some?
Hi Carol,
So it's a year later. Hope you have been enjoying living in your home by now!:no:
What was your solution to the clearance problem?
We are working on the same thing now replacing an older furnace.
~SNICKER~ I sure hope "Carol" was not just some guy pretending to be a chick.
I have seen where some guys do this 'cause they think they will get faster and better information if the tradesman think they are helping a female.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
