Furnace Flame To High - HVAC - DIY Chatroom Home Improvement Forum
Old 10-14-2009, 05:07 PM   #1
Furnace Flame to high
I have a very old International furnace, we recently just moved in and are trying to save on cost. We have comepletely cleaned the furnace and it is obvious that it hasn't been maintained in years. The flames are very high and orange, and when we adjusted the regulator to where the flames are blue and 1'' high the last burner goes out. Do we need to replace the gas regulator valve, or is there anything else you could suggest before we call a proffesional?
tltackovich is offline   Reply With Quote
Old 10-14-2009, 06:22 PM   #2
You need to adjust the regulator using a manometer to make sure the pressure is set to mfg specs. May be something as a burner air adjustment to cure the flame problem. I would suggest you call a tech before you cause damage to your property or yourself.
SKIP4661 is offline   Reply With Quote
Old 10-15-2009, 11:05 AM   #3
re:
I actually got the answer to my question last night, we had someone come take a look at the furnace. Oddly, and I didn't no this the flames on my furnace were normal, becasue I have a pretty ancient unit. The last burner that had the 'normal' looking flames was the problem. THERE WAS A SPIDER WEB in the orificer. That was the only problem.
Luxaire furnace flame out Tuckrb HVAC 14 01-28-2012 11:00 AM
Furnace burners flame out after a few seconds snurb HVAC 3 01-13-2009 08:58 AM
New High Efficiency Gas Furnace & Hot Water Heater frank08226 HVAC 2 04-17-2008 01:06 PM
How to get to furnace flame sensor???? Emporio HVAC 10 02-01-2008 04:08 AM
High Eff. Gas Furnace..? Kyle HVAC 17 12-16-2007 12:17 PM
