#1 |
furnace filters
my question is this..
would it hurt anything..ie..reduced airflow...if I were to lay filters over my cold air intake(s).. |
#2 |
World famous jerk.
furnace filters
Probably not, as long as they weren't permitted to plug up. In some systems, that's where the filter is installed. If you're doing demolition or construction work in the house, it might even be advisable to do as you propose.
#3 |
furnace filters
thank you for the quick reply..
just replaced the furnace filter ..leading from furnace to ducting..at the furnace... and walking out this morning..wondered if it might help keep dust and cat hair out of the furnace to lay filters over the air intakes.. Thank you again |
| Display Modes | |
| Heil Furnace Burner Problem | timothyr | HVAC | 78 | 01-18-2013 07:49 PM |
| Furnace not firing | jax | HVAC | 5 | 02-22-2009 01:41 PM |
| Replacing My Furnace, few simple questions | compression | HVAC | 10 | 02-03-2007 06:00 PM |
| Could installing a furnace to the floor joists cause the floor to slope? | JKL | HVAC | 5 | 01-03-2007 10:23 PM |
| Furnace does't start when Fan is 'auto' | stepicz | HVAC | 2 | 10-18-2005 07:10 AM |
