Furnace Filters - HVAC - DIY Chatroom Home Improvement Forum
Old 12-22-2008, 07:21 PM   #1
Furnace Filters
how do you know what brand or what type of air filter you should get? I Have heard of some good places
Furnace Filters
kyleitis is offline   Reply With Quote
Old 12-22-2008, 07:39 PM   #2
biggles's Avatar
if you just have a single filter that slides into the return duct 1" at the furnace there are only a few choices.install a pleated 1" that will fine filter the dust and dirt more then your typical fiberglass type.HD/Lowes standard filters are avalible.....check out www.grainger.com for a local location for the pleated types.if you go with a pleated changeout realize it will cut down some of the air in heating or cooling cycles,and the changing of it is more frequent.
Old 07-03-2009, 08:03 PM   #3
Changing a furnace filter
Thank you for sharing how to do it and where to get the filters. http://www.iaqsource.com/furnace_filters.php
princecuddlebug is offline   Reply With Quote
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
furnace filters eager2lern HVAC 2 12-03-2006 08:52 PM
