Furnace Filters - HVAC - DIY Chatroom Home Improvement Forum
Old 11-27-2012, 04:42 PM   #1
furnace filters
My furnce accepts a 4 or 5 inch thick filter. Should i use the thickest?
pbermagic is offline   Reply With Quote
Old 11-27-2012, 05:26 PM   #2
Rewards Points: 1,216
What was there to start with? Your choice how much dirt you want to catch. 4 " should do right or maybe a 4" with a 1" pre filter.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 11-27-2012, 05:33 PM   #3
Items wanted: Time
Rewards Points: 150
Do not use 2 filters, use 4 or 5" that fits snuggly.
NiNe O is offline   Reply With Quote
Old 11-27-2012, 05:47 PM   #4
Nothing wrong with a 1" pre filter if preferred. Have seen them zillions of times in all types of applications.
Old 11-27-2012, 05:49 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 386
5" will fit the tightest and have less air/dirt leakage around the filter and is propbably better value per dollar and will last longer.
Old 11-27-2012, 05:56 PM   #6
Items wanted: Time
Rewards Points: 150
Why in the hell would you put a filter that lasts 1-2 months in front of a filter that last 6-12 months. What is that 1" filter going to catch that a 5" filter won't. All you are going to do is restrict airflow quicker.
Old 11-27-2012, 06:00 PM   #7
Items wanted: Time
Rewards Points: 150
And I don't care how many times you've seen it. You know how times I've seen a dog piss through a condenser? Zillions. Still not going to train my dogs to do it.
Old 11-28-2012, 06:00 AM   #8
"O eN iN Take a chill pill"
Old 11-28-2012, 06:36 AM   #9
Items wanted: Time
Rewards Points: 150
Just getting a point across.
old furnace with bizarre filter setup utek HVAC 2 10-14-2013 08:49 PM
Heil Furnace problem - is is the undersized vent? mpmusicny HVAC 8 11-20-2012 12:47 PM
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 08:43 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 07:06 AM
