-   -   Furnace filter recommendation? (http://www.diychatroom.com/f17/furnace-filter-recommendation-100971/)
kcrossley2 04-09-2011 02:54 PM
For several years I've been using 3M's BETTER Air Filters with Micro Allergen Extra Reduction. I've used these on a Goodman gas furnace where the filter is mounted on two return ducts, instead of the furnace itself. I was recently told that this type of filter may be too restrictive, which is causing my system to short cycle.
What brand/type of filters are best for my setup?
Thanks.
yuri 04-09-2011 04:08 PM
True Blue pleated Merv 7 or Merv 8. Available at HDepot in Canada. Not sure if the US stores stock the same product line.
concretemasonry 04-09-2011 04:34 PM
In the U.S. they are in green packages at the HD. After dealing with the performance of the restrictive performance of the 3M Filtrate, I switched a few years ago to the Merv 8 filters to avoid choking the system.
I have a slight allergy to cats, medium to ragweed/goldenrod and severe to horses. Fortunately, no horses in the house and my 2 large, black cats never bother me and my filters are quite clear when I change them every month or two. I run the fan 24 hours for 5 months when heating/circulating and on automatic when cooling.
Dick
beenthere 04-09-2011 05:04 PM
What size furnace, and what size are the air filters?
kcrossley2 04-09-2011 05:13 PM
Not sure of the furnace size, but one filter is 25x25 and the other is 14x14.
beenthere 04-09-2011 05:17 PM
Depending on furnace size, and return duct size, the 2 filters may be large enough that you canuse those filters without adverse effect.
