Furnace Fan Wont Start - HVAC - DIY Chatroom Home Improvement Forum
Old 10-31-2010, 08:56 AM   #1
Furnace fan wont start
My furnace fan will not start in auto mode or manual on mode. However, if I set it to manual on I can get it to run by carefully spinning the fan blades manually. This will start the fan and it will continue to run fine until I turn it off. At least I have heat but I would like to be able to get it working properly so that I can set it back to auto mode. Any ideas?
pecosgaspacho is offline   Reply With Quote
Old 10-31-2010, 09:12 AM   #2
An old Tradesmen
Rewards Points: 7,384
Could be a bad run cap.
Old 10-31-2010, 10:05 AM   #3
Any idea how to test it?
Old 10-31-2010, 10:33 AM   #4
HVAC / Plumbing
with a capicator tester
kenmac is offline   Reply With Quote
Old 10-31-2010, 09:15 PM   #5
My experience says starter capacitor distorts to some degree when it goes. Probably on start up. If it looks like it got a bulge on top or side, it probably went. Wouldn't hurt to wiggle some wires that come out of motor where they connect to a board somewhere. Could be loose from vibration of slightly corroded. Do that with safety switch off.
diyorpay is offline   Reply With Quote
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 02:24 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
