Furnace Fan Won't Shut Off - HVAC - DIY Chatroom Home Improvement Forum
Old 12-07-2010, 11:20 AM   #1
Furnace fan won't shut off
Did not notice this summer whether or not this was happening, but very noticeable now that the weather is getting colder. My heat is set to on....fan to auto. When desired heat is reached the unit shuts down, but there is cool air blowing through the vents. Went to basement and can hear the fan running. This is constent. I am not sure how to turn it off??
dritches is offline   Reply With Quote
Old 12-07-2010, 11:45 AM   #2
HVAC / Plumbing
have you done any wiring, replaced t.stat ,etc,etc, ? If not probably stuck fan switch,relay. How old is the furnace ? this info. would help
kenmac is offline   Reply With Quote
Old 12-07-2010, 12:27 PM   #3
Rewards Points: 119
Could be a stuck relay, shorted circuit, or possibly simply the t-stat is improperly wired?
Nick DIY is offline   Reply With Quote
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Armstrong Furnace and Aprilaire humidifier wont shut off! HELP! scott0949 HVAC 8 12-09-2010 07:30 PM
Luxaire furnace blower will not shut off danaugstin HVAC 1 10-06-2009 10:14 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Oil furnace won't shut off tef HVAC 3 11-13-2007 09:43 PM
