-   -   Furnace Fan Will Not Stop - Help (http://www.diychatroom.com/f17/furnace-fan-will-not-stop-help-62484/)
cmr_3168 01-22-2010 08:37 AM
I was installing a new thermostat. I had to run a 7 conductor wire so that I could have a common. My system is a Amana Distinctions Heat Pump with a gas back-up (aux). When I put the new stat on (Debonair 400) it would not leave the off mode. I could not get it to go to heat or cool. I got concerned so I went to hook the old stat back up. When I removed the new stat, the fan on the furnace kicked on with nothing connected. I immediately hooked up the old stat and it will not shut off. The unit is not responding to the stat. I removed the fan wire at the control panel (G) for the thermostat and the furnace - nothing happened. The unit will not heat or cool either. The only way to stop the furnace is at the breaker (I do not have a switch at the unit).
What could be the problem?
cmr_3168 01-22-2010 11:48 AM
The reason I changed the stat is because the original stat was a HoneywellFocusPro 5000. It seemed like a great stat except you can not change the "deadband" on the stat. If I set the temp to 68 degrees heating mode, it would cycle on and off every 5 minutes. My house never got to 67 degrees. The internal setpoit was like a 1/2degree.
My bills are skyrocketing with the constat starting and stopping of the unit. I am used to the thermostat calling for heat when it drops 2 degrees. There is no setting in this stat to change this. Any thoughts?
SKIP4661 01-22-2010 03:02 PM
My guess would be you blew the low voltage fuse on the air handler board. The power should always be turned off before any service is performed.:thumbsup:
cmr_3168 01-22-2010 03:16 PM
Is there a way to tell if the fuse is blown or does the fuse just have to be reset?
Where is the air handler board usually located?
Marty S. 01-22-2010 05:57 PM
Not positive but I think the fuse is on the furnace control board on that model. Will look like a 3 amp blade type car fuse.
Tator1076 01-22-2010 07:10 PM
I hate to tell you. I think that t-stat is not made for heat pump and gas furnace back up. You need the honey well 5300 touch screen.
cmr_3168 01-23-2010 09:22 AM
We moved in the house this summer. The honeywell th5000 worked the unit. The range to call heat is so small it cycles often. There are options in the honeywell stat for heat pump.
cmr_3168 01-25-2010 08:28 AM
I got the fan to stop. The low voltage fuse on the control panel had failed. I replaced the fuse and now the fan has stopped and is operating properly. This does not help with the unit continually cycling, but I have heat again!
