Furnace Fan Will Not Come On - HVAC - DIY Chatroom Home Improvement Forum
Old 10-23-2013, 01:40 PM   #1
Furnace fan will not come on
Hi All,
I'm hoping to get some pointers.
Now that the weather is getting cooler again, I went out to get the garage gas furnace going again. I lit the pilot light the turned up the thermostat. The furnace fired up just like normal . Waited a while but the fan did not turn on. Then of course the furnace shut down to, what I assuming, to be a safty feature since the fan did not start up. My thermostat has the option for the fan to be "On" or "Auto". Nether would start the fan. The fan turns freely and worked just fine when I turned it off at the start of summer. Any ideas?
Tim
Merccooper is offline   Reply With Quote
Old 10-23-2013, 04:40 PM   #2
An old Tradesmen
Rewards Points: 6,870
Moved to HVAC forum.
Old 10-23-2013, 04:58 PM   #3
biggles's Avatar
do you have a solid state control module within that furnace? if you do the fan relay mounted on the board might be shot...with the fan not running from the FAN/ON position on that stat
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
