-   -   Furnace fan speed (http://www.diychatroom.com/f17/furnace-fan-speed-15579/)
Kyle 01-14-2008 08:40 AM
Furnace fan speed
Does changing the fan speed on a high effecient, variable speed gas furnace decrease it's efficiency?
bigMikeB 01-14-2008 04:47 PM
It does more than that, the reason it's variable speed is to work in series with the heat or cool function that is running for optimum performance.
chris75 01-14-2008 05:07 PM
cold air is heavy so it needs a faster speed, warm air is lighter so a slow to medium speed will work.
bigMikeB 01-14-2008 05:11 PM
Too fast a speed for cooling and you don't get the desired cooling from the coil. Too slow a speed for heat and you trip out the high limit and cut down on the life of the heat exchanger. A variable speed furnace makes these speed changes through a micorprocessor automatically.
chris75 01-14-2008 06:37 PM
Thanks, I live in new england and a popular heating method is a hydro air, so no high limits, and I've never seen cooling on anything but high speed, but I like the idea of a variable speed, I can see the advantages of it.
Kyle 01-14-2008 09:16 PM
I brings up another question that I have had. When I bought the furnace, it being a variable speed, I thought that the speed would automatically change as needed. But now it seems that the motor has three speeds - slow, medium, and fast. The blower is louder than the one I had which was 20 years old. The company is coming out next week to set the motor to a slower setting, but is that the right way to address the issue?
chris75 01-14-2008 09:24 PM
What you have is a 3 speed motor, pretty common around here, they are set up with a heat and a cool relay, so two speeds can be used... but they are not variable...
Kyle 01-14-2008 09:41 PM
That doesn't make me very happy. I was under the impression that I had a variable speed motor. Is there a significant difference? Can I keep the fan speed to medium without any issues? What is the purpose of three different fan speeds?
HvacWiz 01-14-2008 09:44 PM
High speed for cooling, low to medium speed for heat.
chris75 01-14-2008 09:48 PM
Around my parts they use high speed for AC, and medium speed for heat, i've never seen low speed used.. I'm not a duct guy, so I cant really tell you all the theory behind efficiency with a 3 speed motor and a variable motor...
duffers 01-16-2008 08:27 AM
so if i understand this correctly, if you have a variable speed furnace, you need to manually switch it from summer to winter mode? The thermostat doesn't do this automatically for me?
chris75 01-16-2008 05:19 PM
A variable speed furnace is one that is variable, usually has senors inside and out to slow the blower down to 10,20,30,40,50% or whatever its setup to do,
sort of like the newer cars heating system, it slows the blower down after reaching the desired setpoint...
bigMikeB 01-16-2008 05:29 PM
There is a very significant difference in the price of a variable speed furnace and a normal furnace. All new basic furnaces have at least two blower speeds, most have three. The motor in a variable speed furnace is operated by a micro processor in the unit, that takes temps and pressures from various points in the unit and matches the speed accordingly. They do save a fair amount on utility bills over a standard unit. I hope you have a signed contract from the installer, so you have some recourse.
