Furnace Fan Runs All The Time - HVAC - DIY Chatroom Home Improvement Forum
Old 02-07-2010, 01:35 PM   #1
Furnace fan runs all the time
I have a Lennox heat pump and gas furnace. I replaced an old mercury thermostat with a Honeywell rth3100c1002 digital non programable thermostat. The fan is set to auto but runs all the time. If I lower the temp setting by 1 degree it will shut off, then I can raise it back and it will stay off until the furnace turns on again, then it stays on. I have rechecked the wiring charts and it is wired correctly. Is there a setting for this or is it just a defective thermostat?
Also, the fan turns on as soon as it calls for heat, is this normal with heat pumps? The old thermostat did the same thing.
gsoukup is offline   Reply With Quote
Old 02-07-2010, 08:44 PM   #2
Rewards Points: 502
It sounds like your have the Fan wire on the wrong terminal.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 05-13-2011, 05:07 PM   #3
We did the same switch on the thermostat. went from mercury to programmable. seemed to work on ac/heat but fan never turned off. Then had to replace blower motor now all it does is fan runs all the time. this is a heat pump system and there are four wires to thermostat and another not used. Wasn't used on mercury switch. Wiring going back to unit doesn't seem to match but wrote down where all wires came from thermostat.
azsungal77 is offline   Reply With Quote
Old 05-13-2011, 05:32 PM   #4
So what are the wires hooked to? I'm used to r,c,g,y,o,w and e connections on a heat pump thermostat. Maybe one of the other guys knows how to make it work with 4 wires.
Installing furnace in a closet djlazar HVAC 10 01-23-2010 11:34 PM
furnace randomly shuts down sspeed HVAC 12 12-17-2008 05:28 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Fan runs constently Furnace won't fire BSO HVAC 1 11-16-2008 08:40 PM
