Furnace Fan Running Continuously - HVAC - DIY Chatroom Home Improvement Forum
Old 01-24-2009, 09:10 PM   #1
Furnace fan running continuously
Hi, I have a 1991 Snyder General Furnace. Recently the exhaust blower fan has been running continuously but heat has not been coming on.
The only way to get it working is to shut off the thermostat and turn it back on - for some reason this does the trick.
If anyone has any ideas on what may be causing this problem... it would be greatly appreciated.
Joeysmom is offline   Reply With Quote
Old 01-24-2009, 09:36 PM   #2
You are not very clear, are you saying that your furnace is heating fine, but the draft motor is staying on all the time, or are you saying you have no heat and the draft motor runs all the time. There is a difference; 1 indicates a relay sticking and the other indicates the pressure switch not closing, need more info.
sgthvac is offline   Reply With Quote
Old 01-24-2009, 09:39 PM   #3
biggles's Avatar
the ID is only running when the stat calls for heat...as it should?tap the pressure switch(handle of a screwdriver) that the rubber tube goes to.the 2 wires connected to it are the circuit for your main burner,and when the ID runs that switch is suppose to close from the air pressure going into the furnace.remove the tube could be moisture in the switch.
HELP! Electric furnace won't stop running! knchat HVAC 3 12-28-2011 08:38 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
Bryant Furnace Blower Running Constantly GhostBuster HVAC 15 11-30-2008 09:08 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
furnace blower keeps running dmbrasket@hotmail.com HVAC 7 02-03-2008 03:57 PM
