Furnace Fan Help - HVAC - DIY Chatroom Home Improvement Forum
Old 12-05-2009, 05:31 PM   #1
furnace fan help
I have a honeywell programmable thermostate with to wires going to my furnace, i am now using my wood stove and would like to turn the furnace fan on to move heated air without turning on my furnace, how can i hook my furnace fan up to be able to use. any info would be appreciated- thanks
mikeo is offline   Reply With Quote
Old 12-05-2009, 05:41 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,862
G on tstat to G on furnace circuit board. Turn fan to ON at tstat. Need a 3rd wire to do that. What is the make and model of the furnace? You may be able to wire a toggle switch between R and G on the outside of the furnace to do the same job.
Old 12-05-2009, 06:09 PM   #3
make is Luxaire model G9T0601OUPB13C Yhanx for reply
Old 12-05-2009, 06:12 PM   #4
Make Luxaire Model G9T0601OUPB13C
Old 12-05-2009, 06:25 PM   #5
Hvac Pro
yuri's Avatar
If it has a circuit board with r, w, y, g then you can wire it the way I said. Instead of running a wire to the tstat you can use a #18 stranded pair of wires and a Radio Shack toggle switch on the side of the furnace to do the job.
Old 12-05-2009, 06:27 PM   #6
It does have a circuit board, thanx alot i will try that.
Old 12-05-2009, 06:58 PM   #7
thank you very much, i hooked it up like you said and i now have a fan- family thanks you very much
Old 12-05-2009, 07:43 PM   #8
Hvac Pro
yuri's Avatar
Glad it worked out. Pay it forward, help others.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 02:24 AM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 07:06 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
