Furnace Fan - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-25-2010, 03:26 AM   #16
An old Tradesmen
Rewards Points: 6,876
If its battery operated. You only need to connect one more wire to it. To run the fan.
Old 10-25-2010, 09:29 AM   #17
Furnace fan
Beenthere - the thermostat I was planning on ordering is a Honeywell (no battery). It can be view at: http://www.honeywell-thermostat.com/...l/T87N1000.htm
Your thoughts/comments please.
elayr is offline   Reply With Quote
Old 10-25-2010, 12:17 PM   #18
HVAC / Plumbing
it's just your basic t.stat. It will work for what you want
kenmac is offline   Reply With Quote
Old 10-25-2010, 12:38 PM   #19
Furnace Fan
I appreciate your input! I apologize for being so ignorant of this subject. - elayr
Old 10-25-2010, 03:59 PM   #20
An old Tradesmen
Stay clear of that thermostat.
You need to add a resistor to the wiring at the furnace for it to work right. Its a power stealing thermostat.
Old 10-25-2010, 06:00 PM   #21
Furnace Fan
Beenthere - what thermostat would you recommend I buy. I don't need anything fancy! v/r elayr
Old 10-25-2010, 07:32 PM   #22
An old Tradesmen
A simple battery operated Honeywell thermostat.
Similar to the TH4000
Old 10-25-2010, 11:00 PM   #23
Furnace Fan
Beenthere - yet another dumb question. I was looking at a Honeywell Pro 5000 thermostast. In reading the specifications for this unit it stated: Battery Operated or Hardwired. What does this mean? rsvp elayr
(Are you tired of me yet?)
Old 10-26-2010, 04:15 AM   #24
An old Tradesmen
The 5000 is a nice thermostat. And will work for what you want it to do.
What the description means. Is that it can be ran by using 24 volt power from the furnace/air handler by wiring up the equipments common to its common. Or, it can be ran by batteries on equipment such as yours.
Old 10-26-2010, 09:50 AM   #25
Furnace Fan
Beenthere - I'll order one, install it and see what happens. I'll get back to you in a week or so. Many thanks - v/r elayr
Old 10-29-2010, 11:21 AM   #26
Buy our AirCycler FRV and mount it by the furnace where you can pick up R, C & G.
R is 24VAC, C is the common and G is the fan control wire.
Your 2 wire thermostat is just R and W. The furnace turns the fan on by itself from a timer. You would need to run more wires to use a thermostat that energizes G.
The AirCycler FRV will control the fan and you can keep your existing 2 wire thermostat.
Jason
JasonW is offline   Reply With Quote
Old 10-29-2010, 02:37 PM   #27
An old Tradesmen
Seems your posting more to advertise. then to offer real help. thats not allowed.
You can how ever, buy advertising. Us the contact us tab at the top of the page.
Old 11-06-2010, 12:36 PM   #28
Beenthere and Kenmac - I want to thank-you for your guidance and patience. I got a battery operated thermostat and wired it according to instructions. Fan On!! Wife thinks we should get a heat pump and new variable speed air handler/controller. Oh well- again many thanks v/r -elayr
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 02:24 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
