Furnace Fan - HVAC - DIY Chatroom Home Improvement Forum
Old 05-16-2008, 09:43 AM   #1
Furnace Fan
How do you keep your basement and main level a more even temperature. Our furnace guy was here yesterday and he said to leave the fan running all the time. I think that would drive me crazy but he claims it is the only way to have a more even temp between the 2 floors.
Jeep is offline   Reply With Quote
Old 05-17-2008, 05:52 AM   #2
oops, did I do that!
If you have some time to spare, try adjusting your dampers or diffusers. If some areas seem to have a lot of airflow, adjust the dampers or diffusers closed a little. This will force more air somewhere else...hopefully where its needed. You really shouldnt need A.C. in the basement, so close them first, then move up to the main floor...etc. Make sure your blower is running at high speed.
Its called balancing your system. Check the filter. If the system WAS cooling the upstairs, and now it doesnt, you may need the evaporator cleaned, pet hair, dust and debris may restrict air flow over time.
Running the fan all the time is not a good idea.
8 Ball is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 01:24 AM
Furnace Help tuasoi HVAC 2 11-29-2007 12:54 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 05:00 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 01:19 PM
