Old 01-18-2009, 07:57 PM   #1
Furnace exhausting is freezing up
My parents live in a very cold weather area. Every winter ice forms on the exhaust vent from the gas furance. In addition water leaks on the bedroom ceiling. I assume this is from condensation or from the ice. I had them insulate the the exhaust vent in the attic. Didn't work.
garbageman1 is offline   Reply With Quote
Old 01-18-2009, 10:50 PM   #2
Dr Heat's Avatar
is the ice inside the pipe are the pipes leaking or is the ice forming on the outside of the pipe?
Dr Heat is offline   Reply With Quote
Old 01-20-2009, 03:39 PM   #3
It ices up on the exterior of the house. Eventually water (ice melt) or condensate is leaking BR ceiling.
Old 01-20-2009, 11:14 PM   #4
Dr Heat's Avatar
The PVC should totally sealed and pitched toward the furnace; therefore, no leaks should exist.
When a flue is run though an unconditioned space it needs to be insulated so the temp in the flue will stay high enough to vent properly.
I use pre formed rubiflex and tape the seams with mastic tape.
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 03:24 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
Help! My furnace won't stay on! It's freezing in my house! tracyrus11691 HVAC 2 11-21-2008 06:54 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
