Old 08-30-2007, 10:26 PM   #1
Question
Furnace Exhaust To Outdoors
I recently purchase a brand new home and have a question regarding the proper installation of my gas furnace exhaust plumbing.
The exhaust comes out the top of the furnace and along the basement ceiling out to the back of the house ( as well as the intake ). It runs about 15 ft. along the ceiling from the furnace until it clears a support beam, then goes straight up 1.5 ft. on a 45 degrees then goes another 10 ft. along the ceiling and out of the house. Should the slope or the angle of the exhaust plumbing run down away from the furnace slightly? Or, is level sufficient? The length of the exhaust is about 20-25 ft.
It seems to me that when condensation builds up in the exhaust it will roll back into the furnace. Here is why I think this....
Between the first elbow or 90 fitting that makes the exhaust level above the furnace (which seems too low) and the next elbow that brings it up around the support beam ( the 15 ft. run ) is not level, and in fact slopes slightly toward the furnace!! Not to mention again that after that it goes straight up! I have a bad feeling about this.
I move into the house in three weeks and have a Pre Delivery Inspection coming up. Can anyone who knows HVAC reply with some advice?
Thanks,
Frank
celticFC is offline   Reply With Quote
Old 09-01-2007, 02:27 PM   #2
hi frank , condensing furnaces already have built in drains to accomodate this drainage as you'll see when u install this system have fun , Jack
rojacman is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 09:31 AM
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 02:24 AM
Furnace not firing jax HVAC 5 02-22-2009 01:41 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 06:00 PM
