Furnace Exhaust Making Sloshing Sounds - HVAC - DIY Chatroom Home Improvement Forum
Old 02-15-2013, 12:15 PM   #1
Rewards Points: 87
Here is a photo of my furnace exhaust and intake running out the wall.
My problem is that this morning I went to turn my furnace up to start doing some work in the area and as my furnace warmed up I could hear a sloshing sound in the exhaust (left side in photo) pipe. Similar to if you push water around in the bath tub or gentle waves on a beach or lake.
Once the furnace gets going the sound stops.
I then went outside and could see some condensation hanging on the inside of the exhaust pipe. Which makes sense as it pumps out hot exhaust air and it winter here.
I then looked at the exhaust pipe inside. And noticed that between the furnace and the wall exit it dips and then rises. Or maybe just rises.
At the furnace side the the exhaust pipe is 2" above the bottom of the joists.
At the wall side the exhaust pipe is 5" above the bottom of the joists meaning my exhaust pipe is effectively sloping back towards my furnace.
Here is a short .mp3 format recording of the exhaust pipe I made with my laptop: http://cl.ly/3S0p25172G1U you can clearly hear the sloshing in it.
This furnace has passed inspection but I cant imagine that having a exhaust pipe building up with condensation is good in any way.
How big of a deal is this.
I will be calling the people who did the furnace.
hellonoko is offline   Reply With Quote
Old 02-15-2013, 12:40 PM   #2
Pipe sloping towards the furnace is correct. Should be supported along the way so no sags. Condensate trap or line plugged will cause a sloshing sound.
The Following User Says Thank You to Marty S. For This Useful Post:
drtbk4ever (02-15-2013)
Old 02-15-2013, 12:46 PM   #3
Rewards Points: 87
There is a clear sag in the line. Do I need to remove the water before fixing this?
Old 02-15-2013, 02:34 PM   #4
Rewards Points: 24
You don't need to remove the water first. When you correct the sag, the water will drain back into the furnace drain.
djlandkpl is offline   Reply With Quote
Old 02-15-2013, 04:37 PM   #5
Rewards Points: 87
Thanks, pushed the pipe up for the time being to drain it.
Glad I found this before I put insulation and everything up.
Tags
exhaust furnance
Furnace exhaust Bruett HVAC 5 01-13-2013 09:59 AM
Furnace exhaust - out or up and out? justininc HVAC 10 09-06-2011 03:51 PM
Furnace exhaust pipe and ice damming idunno HVAC 1 05-01-2011 09:53 PM
Pilot light going out often...and furnace making a big "boom" sound Beth777 HVAC 20 01-22-2011 04:27 PM
Furnace Exhaust Fan Always On kevmccauley HVAC 7 07-14-2010 04:35 PM
