Furnace Exhaust Fan Always On - HVAC - DIY Chatroom Home Improvement Forum
Old 07-14-2010, 08:12 AM   #1
Hi there ... I have a gas furnace that has a power exhaust fan on it. This is in a house ~18 years old that I have just bought. I installed a new thermostat since I bought the house ... it now seems that the power exhaust is on all the time ... even though the furnace isn't on ...
Anyone have an idea of why this may be ?? The new thermostat is a Venstar 1900.
Kevin
kevmccauley is offline   Reply With Quote
Old 07-14-2010, 11:45 AM   #2
An old Tradesmen
Rewards Points: 8,174
Look to see if the new stat is a power stealing thermostat. As in it doesn't use batteries, or have a common terminal connection. if so, its the stat.
Old 07-14-2010, 11:57 AM   #3
HI Beenthere .. yeah it is definitely a power stealing stat. I had to connect a spare wire in the bundle to "C" on the furnace. The "C" terminal already had 2 other wires on it ...
Can anything be done about this?
Old 07-14-2010, 02:11 PM   #4
An old Tradesmen
Power stealing thermostats bleed voltage to operate. Furnaces with inducers often do what yours did. Because its just enough current to initiated the purge sequence. But not enough to operate the ignitor relay and begin the safety sequence.
Old 07-14-2010, 04:06 PM   #5
so nothing for a DIYer to fix I guess eh?
Old 07-14-2010, 04:18 PM   #6
An old Tradesmen
You can use a resister across W And C terminal at the furnace, some need to go on to the W and G terminal. Should be able to stop it.
A battery, or a thermostat that uses common from the furnace is a better thermostat.
Those power stealing thermostats use to come with a resistor, for this reason.
Old 07-14-2010, 04:23 PM   #7
Any value resistor? The C terminal is different than a common?
Old 07-14-2010, 04:35 PM   #8
An old Tradesmen
C and Common are the same thing.
1,000 ohm, 1 watt.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Furnace Exhaust To Outdoors celticFC HVAC 1 09-01-2007 01:27 PM
