Furnace Exhaust Fan - HVAC - DIY Chatroom Home Improvement Forum
Old 06-22-2013, 03:57 PM   #1
Osh
Rewards Points: 32
furnace exhaust fan
We turned on the AC for the first time today. It's a 90% efficient furnace so it has a pvc "chimney" out the wall. Walking past it on the driveway I noticed the exhaust fan was coming on and off every 5 seconds or so. The fan feeding the cool air to the house is working fine. Any thing that I should look for first? It does not do it when the heat is on.
Osh is offline   Reply With Quote
Old 06-23-2013, 07:19 AM   #2
An old Tradesmen
Rewards Points: 7,316
What brand and model number thermostat do you have.
Old 06-23-2013, 08:42 AM   #3
Osh
Rewards Points: 32
It's a White Rodgers 1F80-51 programmable. Could it be the batteries?
Old 06-23-2013, 09:18 AM   #4
Rewards Points: 446
When did you install the thermostat?
old_squid is offline   Reply With Quote
Old 06-23-2013, 09:26 AM   #5
An old Tradesmen
It could be the batteries. Replace them. If it still does it. Remove the wire from the W terminal on the furnace board and see if it still does it. If it does, then its something with the furnace board, or a furnace safety.
Old 06-23-2013, 10:15 AM   #6
Osh
Rewards Points: 32
It was the batteries. Weird that it did it only with the AC on and not the heat. The thermostat is well over 20 years old and I can't remember when the batteries were changed last, the display was still working.
Thanks , gotta luv DIY
Old 06-23-2013, 10:25 AM   #7
An old Tradesmen
While I do make money coming out and putting batteries in people's thermostats. I prefer for them to try new batteries themselves first. So they don't fall over when they see what it cost for me to come out and do it.
The Following User Says Thank You to beenthere For This Useful Post:
Ebierley (06-24-2013)
Old 06-13-2015, 04:58 PM   #8
Osh
Rewards Points: 32
Bringing up a 2 year old thread
Same problem as before but remembered this thread. Replaced the batteries in the thermostat again but didn't cure the problem. Removed wire from the W terminal as suggested last time but then the compressor didn't run. Any other suggestions? Furnace board kaput? It's a Armstrong ultra SX 90 furnace.
Old 06-13-2015, 05:03 PM   #9
Hvac Pro
yuri's Avatar
Rewards Points: 2,238
You got some mixed up or shorting wiring. W is ONLY for the heat. Y is for cooling. Been~ mentioned disconnecting W to see if it was calling for heat and running the exhaust fan. Should have nothing to do with the AC not working. That may be a pretty old thermostat and shorting or acting up. Try a new Honeywell one from HDepot. Otherwise you may have a wiring problem or short. Easier to try a new thermostat.
Old 06-13-2015, 05:48 PM   #10
Osh
Rewards Points: 32
The AC is actually working, just that the exhaust fan in running intermittently every 5 seconds or so. I only noticed it while walking down the driveway where the pvc " chiminy' comes out the wall.
Old 06-21-2015, 10:36 AM   #11
Osh
Rewards Points: 32
Just a FYI. After my wife reminded me the thermostat was 26 years old I went and bought a new Honeywell programmable t-stat. Less than 10 minute install and all is good. $50 vs a $150 service call minimum.
Old 06-21-2015, 12:09 PM   #12
Hvac Pro
yuri's Avatar
Now that you are $100 ahead she deserves a nice restaurant Dinner. Red Lobster is good.
Glad you found it and fixed the problem.
Furnace and Water Heater Exhaust dajate HVAC 2 01-27-2013 06:45 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
exhaust smell when the furnace kicks on puchead77 HVAC 5 01-19-2009 01:11 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
