Furnace Electricity - HVAC - DIY Chatroom Home Improvement Forum
Old 03-19-2010, 08:50 AM   #1
Handyman
Rewards Points: 512
Furnace electricity
My landlord had a mid effiency furnace installed before Christmas to replace a real noisy clunker. Both are gas. I just received the hydro bill (every two months) and am shocked to see that it went from $324 to $585!
Water is also included but still...
Sometimes I run a small heater for a couple of hours to heat one room but was doing that before.
The furnace seems to turn on much more frequently than the old one (something like every 15 minutes or so) and I am wondering...
Can a furnace fan draw that much energy? Was I was better off with the old clunker? The new one is a "KeepRite" if that makes any difference.
canadaclub is offline   Reply With Quote
Old 03-19-2010, 09:07 AM   #2
Might there have been a meter mis-read? Compare your bill to the current meter reading.
We recently had a 95% furnace installed just as this cold winter started. We were pleasently suprized to be getting $200 when previous winters with the older system was usually about $250. Then, last month we go a $400+ bill. I checked the meter's current reading and found the reading listed on the bill was beyond the current reading.
HooKooDooKu is offline   Reply With Quote
Old 03-19-2010, 10:01 AM   #3
Handyman
Rewards Points: 512
That was my first (hopeful) guess. They are coming today to do another reading. Fingers crossed! lol
Old 03-19-2010, 10:18 AM   #4
Rewards Points: 590
I wonder if the new one is oversized, because you say it cycles often.
operagost is offline   Reply With Quote
Old 03-19-2010, 10:30 AM   #5
Even if it is oversized, I wouldn't think that could account for an 80% increase in gas use... especially (if like where I'm located) the weather for the last month was a little milder than the two previous months.
Old 03-19-2010, 10:41 AM   #6
Handyman
Rewards Points: 512
I would have thought that oversized would cycle less??
Old 03-19-2010, 11:51 AM   #7
An old Tradesmen
Rewards Points: 7,394
Oversized cycles more.
Oversized is on for a short period of time, and then generally comes on quicker then a proper sized one.
Post full model number of new furnace(won't know if its bigger then the old, but the number helps to know what size furnace we're talking about).
What size is your house?
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 02:24 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
