Furnace Electrical Transformer Fried?? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-03-2013, 11:56 AM   #16
raylo32's Avatar
Rewards Points: 1,254
You might also want to re-check your thermostat wires since you said you just relocated it. Maybe a wire popped off its terminal or somesuch...
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 12-03-2013, 12:00 PM   #17
Hvac Pro
yuri's Avatar
Rewards Points: 1,862
the primary side/120 volts side is the black and white wires. the secondary 24 volt side is the blue and yellow. You should get 24 volts from them, check that. after that you should get 24 volts from the W wire from the tstat when it is calling for heat to the C terminal or yellow wire, if not then it is shot or you got a bigger wiring problem or broken wire. you can also take the W wire and R wire off at your box and using an ohmmeter with alligator clips on your meter ends put them on those wires and have it call for heat. should get 0 ohms or very low resistance. if it is infinity or OL open line then you got an open circuit for some reason. don't use the ohmmeter while holding the probes with your fingers as it will read continuity thru your body and give a false positive result. I am pretty sure yellow is common but really need to see the wiring diagram to be sure. post a pic of that box with the other side facing out so we can read what the terminals are or you list them from top to bottom starting at the transformer and going down to where that blue wire attaches.
Old 12-03-2013, 10:24 PM   #18
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Originally Posted by raylo32 View Post
The box stores sell 24vac doorbell transformers that might work but they won't have the exact same mounting holes as your original.
Im thinking a doorbell transformer is normall between 12-18v depending on how old it is anyway,wont work.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 12-03-2013, 10:26 PM   #19
plummen's Avatar
Its usally pretty hard to smoke a transformer by bumping the wires together on the thermostat end of circuit,if you bump the wires against something metal inside the furnace on the other hand Id say all bets are off though!
Old 12-04-2013, 01:04 AM   #20
DNA
I get voltage across the blue and yellow wires off of the transformer, seems to be doing its job. The furnace won't switch on still. I tested using a spare thermostat and that didn't change anything so it is not the thermostat. What is the best way to find where the electrical fails?
Here are so pictures for you to look at.
This is the electrical box with the new transformer installed.
Here is the front of the electrical box.
Here is a larger view of the furnace
Is there any sort a wiring diagram that I could use for a reference? Its hard for me to follow what the different electronics do.
DNA is offline   Reply With Quote
Old 12-04-2013, 04:13 AM   #21
plummen's Avatar
Disconnect the thermostat wires at the furnace.
Then put a jumper wire from the red/r to the white/w terminals,furnace should come on(you might have to hold in the door switch,couldnt tell from picture)
If that brings the furnace on its time to hook low voltage back up at furnace and check the wires at the stat,can you post a picture of the wires at the stat?
Did you splice anything when you moved stat?
Old 12-04-2013, 05:30 AM   #22
raylo32's Avatar
This is a little OT since the OP seems to have a working transformer now... but for us DIYers who might not be able to get a real HVAC xfmr fast these might be the only things we can get in a hurry on a cold day to get the heat back up and running. They are multi-voltage (different taps) and do have 24vac, 20VA output. Would this work in a pinch? What would happen if 20VA wasn't enough? Would it hurt the circuit board or just burn out the xfmr?
http://www.homedepot.com/p/IQ-Americ...x#.Up8RN8RwqSo
Old 12-04-2013, 05:35 AM   #23
An old Tradesmen
Rewards Points: 6,938
The transformer would burn out. 20 VA at 24 volts is .83 amp.
The Following User Says Thank You to beenthere For This Useful Post:
plummen (12-04-2013)
Old 12-04-2013, 09:01 AM   #24
DNA
This doesn't kick the furnace on, where is the next place to check?
I did not I just got a new wire and hooked everything up where it was before.
Old 12-04-2013, 09:36 AM   #25
plummen's Avatar
A furnace transformer is generally going to be 24v 40-50va if I remember right without digging one up.
Old 12-04-2013, 09:38 AM   #26
Hvac Pro
yuri's Avatar
do you get 24 volts across R and C on the terminal strip with the door switch pressed in. looks like somebody altered some of the factory wiring. R is fed by that pink wire and you may need to trace where it comes from, I suspect the limit control.
The Following User Says Thank You to yuri For This Useful Post:
Old 12-04-2013, 09:41 AM   #27
Hvac Pro
yuri's Avatar
there are 2 types of OEM furnace transformers. 20 VA and 35-40 VA none larger than that.
Old 12-04-2013, 09:46 AM   #28
plummen's Avatar
Yep I was having a brain cramp,40va is what I was thinking but couldnt remember for sure.
Old 12-04-2013, 10:24 AM   #29
Hvac Pro
yuri's Avatar
you ought to see what a mess and disaster using telephone wire instead of #18 wire can do to a modern circuit board. blows their brains and logi circuits. hate that stuff when I run into it.
Old 12-04-2013, 05:21 PM   #30
An old Tradesmen
Doubt its a problem with the thermostat. More likely a limit or roll out tripped.
2 TVs fried: Electrical vs. Comcast Coax Cable Problem LynOprinka Electrical 17 07-16-2012 08:01 PM
No power from Furnace to transformer for HUM bwalbany HVAC 2 01-15-2012 01:25 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
