Furnace Electrical Supply.... - HVAC - DIY Chatroom Home Improvement Forum
Old 12-19-2006, 12:13 AM   #1
Question
A few of us were discussing the proper use of generators over in Electrical and a question came up that you all in HVAC might be able to answer.
Is there a NEC code that addresses if a gas furnace electrical supply consist of a properly size cord plugged into a dedicated outlet?
Currently my own furnace is hard wired into a receptical that has a hot outlet as well as a switch to cut the power to the furnace while being serviced.
The reason for asking is when using a generator supplying power to different appliances by extension cord ... the furnace can then be unplugged and plugged into the extension cord with power from the generator.
Thus the question regarding the NEC code (where a copy is hard to come by for the average homeowner).
We all would welcome your thoughtful suggestions and advise...
caseywa is offline   Reply With Quote
Old 12-28-2006, 08:18 AM   #2
hard wired.
redline is offline   Reply With Quote
Old 12-28-2006, 11:37 AM   #3
Thanks redline. I have a copy of the NEC 2005 code book but it really does not say for sure one way or the other...it leaves it up in the air. I will leave it hardwire and research more into properly using a transfer switch at a subpanel.
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 08:01 PM
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 02:24 AM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 06:00 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
