Furnace Ductwork Question - HVAC - DIY Chatroom Home Improvement Forum
Old 02-17-2012, 08:26 AM   #1
Furnace ductwork question
I am in the process of adding a bathroom in my basement. My issue is the furnace ductwork run directly up the middle of my space. It is possible to move the ductwork tight to one side. The problem is if I do that the very end would be at the doorway entering the other room. The duct is about 3 inches lower than the top of the door opening. Question: can I make the ductwork wider and shorter to maximize headspace and still get the same airflow upstairs? I would have a local HVAC company do the work - I just want to know if I can do this before I call them to come out. Thanks!
ltlbvr is offline   Reply With Quote
Old 02-17-2012, 09:33 AM   #2
Rewards Points: 13,250
In most cases yes. They can change it to rectanguler.
But someone really can give you the best ansewers if they were on site.
Old 02-17-2012, 04:39 PM   #3
REP
I would have to see what you have there now(maybe a picture) ,but the answer is most probably.Also most probably it will be or need to be a custom fitting which isn't as big a deal as it sounds but air flow needed will be part of the design.
REP is offline   Reply With Quote
Old 02-17-2012, 07:44 PM   #4
Rewards Points: 582
yes it will work remember your talking about a small room.. bath ..which would not require much cfm...
Old 02-18-2012, 05:39 AM   #5
An old Tradesmen
Rewards Points: 6,462
he said there are other supplies to the floor above that will come off this duct. So probably can't make it smaller, and still have enough air flow.
Old 02-18-2012, 07:45 AM   #6
Rewards Points: 582
thanks....I thougth he was adding a duct to bath...guess I read wrong...
Old 02-18-2012, 07:54 AM   #7
An old Tradesmen
He'll probably be adding a supply to that bath also. So you read it half right.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (02-18-2012)
Old 02-18-2012, 08:27 AM   #8
Experienced
Jackofall1's Avatar
Changing the ducting to rectangular is exactly what could be done with your situation, as long as the aspect ratio (width to height) remains within reason. From memory I believe that ratio should not exceed 5 to 1.
EDIT: After looking up the recommended duct aspect ratio, it is no recommended to exceed 3 to 1, however the length of that duct will determine system losses, a short run of 5 to 1 will not have much effect at all on the system losses.
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
Old 02-18-2012, 08:45 AM   #9
An old Tradesmen
8X12=6X17=5X22. 8X18=6X26=5X34.
Can make for some very wide duct work as you decrease the duct height.
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 09:31 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
Question about light in furnace rm Sherpa Electrical 7 12-22-2008 08:10 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
