Furnace Duct Noise - HVAC - DIY Chatroom Home Improvement Forum
Old 10-19-2013, 01:51 PM   #1
Furnace Duct Noise
I live in a 3 bedroom bungalow with a reasonably new high efficiency FAG furnace. When the heat comes on, which it has started to do now, the ducts make a lot of noise... banging and thumping. I know the cause is expansion and shrinking from the heat but I don't know why my duct work does it and other houses do not. It is a completely unfinished basement so I have access to the ducts. Is there a common way to stop this from happening?
edwilson is offline   Reply With Quote
Old 10-19-2013, 02:57 PM   #2
Rewards Points: 6,652
It is normal for duct work to expand and contract. A lot of reasons, is due to it is rubbing against the wood framing, or no flex joint between the furnace and the trunks. Try and determine where the expansion and contraction is coming from, and then you can work from there.
Old 10-19-2013, 03:25 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 174
go downstairs and get the wife to turn up the tstat. Then you can find where it is banging. May need to reinforce that spot with some sheet metal. houses expand contract with humidity and seasons change so you cannot compare 2 houses.
Old 10-21-2013, 06:25 PM   #4
Rewards Points: 150
what do you mean when you say the heat comes on? are you talking about when the burner ignites or are you talking about when the blower kicks on? If it bangs when the burners ignite you might want to have it looked at. If it's when the blower kicks on follow Yuri's advice and wait for system to cool down then have somebody turn up heat and wait while you are standing beside it. I would start with the plenum on the top or side of furnace. sometimes they pop or bang when the blower first kicks on.It might just require some type of stiffener to be attached to the side to take out the flex.
hpyjack2013 is offline   Reply With Quote
Old 10-21-2013, 07:57 PM   #5
An old Tradesmen
Rewards Points: 7,816
It may also be that your duct work is oil canning. This is caused by the furnace being to big for the duct work. Is the new furnace the same BTU size as the old one?
Old 10-21-2013, 09:23 PM   #6
Rewards Points: 150
I wouldn't think an increase in btu would cause furnace to oil can at start up. Now if the blower is much newer and more power????.Maybe the bang isn't an expansion but just the opposite? were there any modifications made to the cold air return(s) which maybe cause a negative pressure inside the blower compartment/plenum when the blower first starts
Old 10-22-2013, 04:56 AM   #7
An old Tradesmen
A newer furnace of the same size may need to move 400 plus more CFM to stay in its safe temp rise range compared to what an olde heavy walled heat exchanger furnace did.
Old 10-23-2013, 02:23 AM   #8
Rewards Points: 1,192
Never heard the term oil canning.
bobelectric is offline   Reply With Quote
Old 10-23-2013, 04:42 AM   #9
An old Tradesmen
Do you remember when motor oil came in 1 quart cans. You inserted the pour spout. Then turned it ove to pour into the fill line, and as the oil ran out, with no other way for air to get into can. The sides of the can sucked in, until the oil stopped coming out while a slug of air when up through the spout, causing the side to come back out.
Old 10-23-2013, 06:36 AM   #10
Rewards Points: 1,300
Interesting...I was always told it refered to the type of oil can used to drop oil a motor, etc. You used your thumb to "pump" the bottom of the oil can to flow the oil out the spout. May be a regional thing
danpik is offline   Reply With Quote
recommend book for DIY Furnace and Duct installation fromscratch HVAC 1 07-20-2011 08:37 PM
Cold air in duct in furnace room? DIYguy2000 HVAC 6 12-23-2009 10:42 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
furnace making noise ja3118 HVAC 1 11-24-2008 10:51 AM
Williams wall furnace whistling noise diyer_mi HVAC 11 10-23-2007 04:05 PM
