Furnace Draft Motor Help - HVAC - DIY Chatroom Home Improvement Forum
Old 03-04-2013, 07:17 PM   #1
furnace draft motor help
Help my furnace draft motor locks up and tries to start but doesnt turn but if I press on one of the two tlrings around the motors drive shaft in it will rotate. Idk if this is like a contactor relay or if its a bad start capacitor or the motor itself is bad. When locking up it hums loud and when I can get started is really loud some sound appears to be from motor drive shaft. Or are there any other parts it could be I have pics also its a janitrol furnace. Have great electronics knowledge but only vaguely familar with furnaces please help
RAIDENGOD is offline   Reply With Quote
Old 03-04-2013, 07:37 PM   #2
Rewards Points: 14,290
Sure sounds like a bad bearing or lack of lub.
Old 03-04-2013, 08:46 PM   #3
how
Rewards Points: 1,104
Can it spin freely on it's own when not powered?
Does it have a capacitor and is it OK?
Do you know if the board is giving it a full 120V?
how is online now   Reply With Quote
Old 03-04-2013, 09:44 PM   #4
Rewards Points: 516
If you have to replace, try to match here:
http://www.fasco.com/documents/pgs051-059.pdf
Then try to get price using the Fasco Model #
http://www.hvacpartsoutlet.com/searc...se&category=27
http://www.electricmotorwarehouse.com/
http://www.cshincorporated.com/
diyorpay is offline   Reply With Quote
Old 03-05-2013, 03:56 AM   #5
draft motor
Yes its getting voltage and spins freely when not powered only when on it locks but I press on the area on outside of shaft and it will go I have to hold it in untill up to speed btelw takes almost 20-30 seconds to get to speed. I dont see a capacitor for this motor
Old 03-05-2013, 06:14 AM   #6
Rewards Points: 196
Time for a new ID motor
HVACTECH96 is offline   Reply With Quote
Old 03-05-2013, 06:22 AM   #7
Before you spend money on a new inducer check the heat exchanger. Take the blower out then crawl up in the blower compartment and look up. The heat exchanger is held together with a bunch of rings which are well known for breaking. If any are cracked or you see rings sitting on top of the blower assembly when removing it then you'll need a heat exchanger and inducer motor which is going to cost as much as a new furnace,or real close.
Tags
draft motor lock
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 02:13 PM
mysterious floor draft craigwc HVAC 0 10-09-2012 01:08 PM
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 08:43 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Tempstar pilot not lighting after draft inducer replacement Kdavid HVAC 53 03-27-2009 02:10 PM
