Furnace Draft Inducer Dying - How To Keep It Going For A Day Or Two? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-11-2011, 11:17 PM   #1
Exclamation
Furnace Draft Inducer Dying - How to keep it going for a day or two?
A couple of years ago I had a new draft inducer put in. It's always made a rattling noise when spinning down. Over the last week or two it's gotten worse and now my pressure switch keeps opening right as the gas goes on.
I'm assuming the motor is no longer turning the right RPMs and generating the right amount of negative pressure. I am getting the error code for pressure switch opened.
I'd really like to avoid moving the family to my mother-in-law's for the night if I can help it. Any ideas on how I can get the motor to make it one more day?
jmnorris is offline   Reply With Quote
Old 12-11-2011, 11:50 PM   #2
I've tried switching the furnace to do high heat only. That did not help. I guess I am hoping I can oil the bearings to get it limping along for now. Might that be possible?
Furnace is a Carrier Weathermaker 8000 Two-Speed 80% from '91 I believe. Looks like the motor is this Carrier HC21ZE118: http://www.ebay.com/itm/Packard-6511...#ht_1091wt_952
Old 12-12-2011, 07:40 AM   #3
biggles's Avatar
check the squirrel cage for crap and does it free spin either direction...WD40 into the shaft motor area might give you a couple of days... spinning it both directions to work it in...check here for http://www.bestbuyheatingandaircondi...ode=fasco-indb pricing..check Grainger Supply on line for local for overnight shipping...availibility
Old 12-12-2011, 05:03 PM   #4
Rewards Points: 490
Alternate source:
Find the right one here:
http://www.fasco.com/documents/pgs068-095.pdf
http://www.fasco.com/documents/pgs051-059.pdf
Then order someplace like here
http://www.cshincorporated.com
diyorpay is offline   Reply With Quote
Old 12-12-2011, 08:17 PM   #5
Thanks for the great info guys.
Bryant furnace inducer starts then furnace locks out Bill412 HVAC 4 10-09-2012 01:13 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Draft Inducer running all the time. jimreed02 HVAC 5 03-18-2011 04:51 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Tempstar pilot not lighting after draft inducer replacement Kdavid HVAC 53 03-27-2009 03:10 PM
