Furnace Dosent Start - HVAC - DIY Chatroom Home Improvement Forum
Old 02-18-2014, 02:30 AM   #1
Rewards Points: 40
furnace dosent start
Help me pleaseee!!!
I went on vacation for 1 week. I left the furnace on. Today I came back and the furnace is off. I try to turn on but it dosent work.
I change the filter and reset the furnace. Still dosent start
Somebody have any idea what happened??? Can be the ignition ??? Or some part frozeen becouse the cold??
Thankss
pavlito24 is offline   Reply With Quote
Old 02-18-2014, 05:08 AM   #2
An old Tradesmen
Rewards Points: 8,164
Did you check for a blown low voltage fuse, or a tripped breaker.
Old 02-18-2014, 06:52 AM   #3
Rewards Points: 40
The furnace is with power. The breaker in the panel is in the correct position ( or you are talking about other breaker?) The low voltage fuse I dont know where is it in the furnace.?
the fan is working. But the flames never begins, so after the furnace try two times for put on the burnes. The fan is off
Thank you
Old 02-18-2014, 07:38 AM   #4
Pavlito: an image of what you have would be helpful. Model # etc. picture of electrical schematic on door etc.
But for most part without knowing what you have it is hard to help except in a generic way.
1). Do you have 120 volts to unit?
2). When you say a fan is running are you referring to a small combustion for the burner or the circulating fan that moves air throughout home?
3). Thermostat is set to heat? Does the fan that circulates air in house work if switched to fan- on?
4). Is door on correctly on unit? Some furnaces have a door/ cover interlock switch that has to prove door is closed before allowing power to continue to burner circuit.
5). Do you hear the ignition controller (clicking) or glow coil (glowing) to try and light pilot flame?
6). Do you own a multimeter or test light to check 120 volts and 24 volts.
Help us out so we can guide you if we can..
Focused2 is offline   Reply With Quote
Old 02-18-2014, 11:06 AM   #5
Rewards Points: 150
Is this oil-(Changed filter) were is your tank located? inside or outside? is there oil in the tank
hpyjack2013 is offline   Reply With Quote
Old 02-18-2014, 11:13 AM   #6
Rewards Points: 808
Did someone siphon out all your oil while you were away?
IslandGuy is offline   Reply With Quote
Old 02-21-2014, 04:48 PM   #7
Rewards Points: 40
The problem is solve, but here an imagen for the igniter
1. The furnace is York. It is connect to 120v.
2.When Turn the fan auto to on, the fan start run.
5. This point I didn't know how to explain when I hear the click, and the flames doesn't start to burn, so after hear two click the furnace turned off. But I was sure ( or 90%) does click came for the igniter. I need to confirmed that.
The problem was found the store that sale supplies for hvac, I spend at least 3hrs. And some stores they asked for the license.
Thanks!!! for help me
**Sometimes me is hard to explain because English is my second language.
Anyway The problem is solve by myself.
HEIL gas furnace will not start. Mikeee HVAC 11 01-11-2015 01:35 AM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
Furnace won't fire, exhaust fan hot and won't start tex800 HVAC 14 10-08-2010 06:48 PM
Oil Furnace Won't start ScottEW HVAC 0 10-05-2010 08:26 AM
Heil furnace won't start - just a click and a hum MrGookat HVAC 4 01-06-2009 07:53 PM
