-   -   Furnace does't start when Fan is 'auto' (http://www.diychatroom.com/f17/furnace-doest-start-when-fan-auto-1155/)
stepicz 10-17-2005 11:27 AM
I recently replaced my old thermostat with a new programmable NOMA 5+1+1 thermostat. This is the first time I am trying to turn the furnace on with the new t-stat and the AC worked fine with it. I followed the manufacture’s recommendation on wiring.
When I put the thermostat to Heat/On position, fan to Auto, and raise the temperature to 80 degrees, room temp was 50 degrees, there was no response from the furnace. The thermostat clicked and “heat” was flushing, which means it was sending a signal to the furnace to kick in, but the furnace would not start. However, when I changed the fan to manual “on”, both the fan and furnace started. When the temperature was reached, the furnace would stop but the fan would go on because it was on ‘on’ instead of “auto”
It is an old
Lennox gas furnace. Would anybody have any idea what could be wrong?
MinConst 10-17-2005 08:41 PM
Sounds like a bad thermostat. I'm not a HVAC guy but it sounds like the auto setting is the culpret. Check the wiring to be sure you did in fact wire it right first.
stepicz 10-18-2005 06:10 AM
Thanks, you were right. You are not an HVAC guy but certainly you are knowledgeable as one. Even before I got your message, I checked the wires and connected the black wire with red one to ‘R’, and it worked. The black one was connected to ‘G’ for unexplained reason. Eh…
